Summarize Feature Values and map it subnetwork controller
1398
05-24-2023 12:12 PM
PhilippSimon
Hello there,
I am not that familar with arcade and I want to create my first more complicated attribute rule.
I have a network controller and some features connected to it. In my case case its about fiber optical networks.
So the controller ist a fiber distribution poin and the clients are some address points. The address points have an attribute field, that indicates the number of households. So now I want to summarize the number of housholds in the subnet and write it to the controller.
Any idea how to do?
Best regards
Philipp
RobertKrisher
If you set the number of households as a network attribute you can use the Set Subnetwork Definition tool to add a Summary Function that will summarize the number of households on that circuit (Subnetwork). You can learn more about configuring subnetwork definitions on this page in the online help.
RobertKrisher
MikeMillerGIS
Esri Frequent Contributor
If you want to write the summaries back to the controller, the batch trace has an option for you.
https://esri.github.io/Utility-Data-Management-Support-Tools/docs/3.1/BatchTrace.html
