Subnetwork Name has slight variations. Can some help explain this?
1690
05-07-2024 05:47 PM
gis_KIWI4
MVP Regular Contributor
Hi Team,
I noticed something in our records which I thought was peculiar.
You can see in the below images the SUBNETWORKNAME is stored in different ways -
"::CB417 Herbert" and "CB417 Herbert"
Why would that be?
The underlying subnet line is "CB417 Herbert"
I have tried updating the subnetwork but it doesn't change anything.
Is there something I might be missing?
gis_KIWI4
@RobertKrisher @MikeMillerGIS
The solution from ESRI team was to export as Asset Package and recreate the Utility Network.
I tried it with a fileGDB and it worked, but it's a pain to do it in the Enterprise DB for now so will leave it until the opportunity to do so presents itself.
Thanks for your help.
MikeMillerGIS
Esri Frequent Contributor
The double :: is used when two or more subnetworks are present and it concatenates them.  Do you have a subnetwork that has no name?
gis_KIWI4
Not that I am aware of. I have checked the subnetwork table and there are no subnetworks where 'SUBNETWORKNAME' is blank.
This behavior has been present right from the start.
Even in places where two subnetworks meet eg - open switch.
The only place we don't usually see a leading "::" is the Transformer.
This is where HV Subnetwork "ends" and LV Subnetwork begins.
RobertKrisher
That looks like it could be a bug, please log a case with support.
gis_KIWI4
Will do.
Thanks Robert.
gis_KIWI4
