Hello all,
I have encountered error while trying to Create Rename Table in Asset Package with the following errors:
This error suggesting that Subnetwork Field Name which created by system when running Add Tier tool should be not nullable. But I did noticed that Add Tiers tools will create a Subnetwork Field Name that accept nulls value (I was just trying to add one more tier in the single-user Utility Network).
Was wondering why is it so? And how to ensure Subnetwork Field Name created is not nullable.
Thanks in advance!
When you add a tier and there is data, it cannot add it as nullable. In the asset package, just delete those fields from your classes. The apply asset package will add these fields/tiers before data so they will be added correctly as nullable.
Thanks @MikeMillerGIS ! Rename Table can be created now. But I have a follow-up question on this. Lets say if I create a new Tier (Water Pressure) in the UNM (has data), and continue to use this UNM model, will this nullable subnetwork field name impact anything in the UNM (not the AssetPackage)?
I do not think there is a big impact. Maybe affects the index long term, not really sure.
