Stage Utility Network Fails
1484
01-31-2022 03:30 PM
GarretGiordanoTOLE
I am running ArcGIS Pro 2.9.1 and I am trying to 'Stage Utility Network' in an empty FGDB. The tool when I run it is producing the following error with no error number:
File "C:\Users\GGiordano\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\common\wrappers.py", line 142, in wrapper
f = func(*args, **kwargs)
File "C:\Users\GGiordano\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\gptools\tools.py", line 247, in run
return stage.main()
File "C:\Users\GGiordano\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\utility_network\un.py", line 420, in main
self.process_layer()
File "C:\Users\GGiordano\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Lib\site-packages\untools\utility_network\un.py", line 386, in process_layer
desc = arcpy.Describe(parent)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 1287, in Describe
return gp.describe(value, data_type)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 384, in describe
self._gp.Describe(*gp_fixargs(args, True)))
What am I missing? I am using the latest untool version.
OSError: "" does not exist
PaulLeBlanc1
Use a service territory feature class instead of a layer.
This will be resolved in a future release of untools, thanks for finding!
PaulLeBlanc1
GarretGiordanoTOLE
Thank you, that worked.
