Something unexpected caused the tool to fail.
2255
08-02-2022 07:45 AM
GIS_Solutions
Hello everyone,
When I run the Update subnetwork tool I get the following error.
The tool gives an error after running for 2 hours continuously. When I look at the Subnetline layer, I saw that it creates 1500 features. But there are about 6500 more features to create, but the tool is breaking. When I run the tool after giving an error, I get the same error after 2 hours again.  I've run the Subnetwork Update tool 5-6 times, and I got the same error after 2 hours in all of them.
When I look at the Arcgis Server logs, I see this error first. "The containing process for System/UtilityNetworkTools' job 'j467e2e4314c44937b698f4fba0f3b082' has crashed."
I am also seeing this error afterwards.
"Processing request took longer than the usage timeout for service 'System/UtilityNetworkTools.GPServer'. Server request timed out. Check that the usage timeout is appropriately configured for such requests."
I set the parameter "The maximum time a client will wait to get a service" to 16000 seconds. But I keep getting the error.
Enterprise 10.9.1
ArcGIS Pro 2.9.3
Oracle 19C
utilitier
Hello @GIS_Solutions
The same issue which I have faced. Can you please try to change the duration of the timeout from below screenshot.
RobertKrisher
It looks like the problem is, as you noted, that the process is timing out. In the past when I've been in situations where I need to trace a large number of networks like this I will write a script that will iterate through the list of dirty subnetworks and update them one at a time.
utilitier
GIS_Solutions
this worked 👍
