Set Terminal Connections GP Tool
2064
12-20-2023 07:38 AM
TobeyKane-Seitz
Hi UN community!
Several months back, I recall using a geoprocessing tool to set terminal connections for lines in a sewer UN - the tool allowed me to honor the digitized direction and modify the terminal connections for lines in bulk, rather than setting them individually. However, I can't seem to find the tool now. Has it been removed/renamed? Does the tool discussed here: https://community.esri.com/t5/arcgis-utility-network-documents/automatic-assignment-of-from-to-termi... accomplish the same thing?
Thanks in advance
MikeMillerGIS
Esri Frequent Contributor
You can def use the Attribute Rule you linked, but the tool you are looking for is here:
https://doc.arcgis.com/en/arcgis-solutions/latest/tool-reference/utility-network-package/modify-term...
MikeMillerGIS
TobeyKane-Seitz
Thanks Mike! Are there benefits to using one vs the other?
MikeMillerGIS
The tool is more for data migration.  The Attribute Rule is used as you edit, so you only have to look at terminals in situations where it cannot figure it out.
