Migration Tool Output Schema
659
10-24-2025 09:46 AM
Lorne_Dmitruk
@RobertKrisher
I'm currently working on migrating a geometric network to a utility network and just a bit a clarification on fields the migration tool adds to schema. In the output schema the following three fields are added in addition to the standard utility network fields:
  • ORIG_FIS
  • ORIG_CLASS
  • ORIG_TYPE
Apart from any merged fields from the source feature classes and objects does the migration tool add any other fields to the output schema?
MikeMillerGIS
Esri Frequent Contributor
I believe those are the only fields added.  They can be deleted as they are only there to provide a link back to the source data.
MikeMillerGIS
