Load Planning in Utility Network
1730
10-27-2024 03:23 PM
RaghavGupta
Hi
Does ESRI provides OOTB in Utility network model for load planning or max number of connections to pole . Is it even possible. In one of the videos on Youtube, it was mentioned it can be done. However, I am not able to find any such links resource on internet.
I am wondering this can be done using Attribute rules but still is there any OOTB capability available
Any help would be appreciated.
Thanks & Regards
Raghav
RobertKrisher
The utility network does not perform those calculations, but the utility network foundation data model contains all the necessary attribution to perform many different calculations like this (which is why the tables have few fields). You can either build your own tool to do this or look for an Esri business partner with a solution that can perform these calculations and integrate with the utility network.
RobertKrisher
Jens_Dalsgaard
Volue, a Scandinavia-based Gold partner of Esri, provides Volue Grid Calculator - a SaaS-based access to performing load-flow- and short-circuit-calculations from directly within ArcGIS Pro or web map.
https://www.volue.com/products-and-services/volue-grid-calculator
Volue Grid Calculator allows calculating on both medium- and low voltage grids.
This product is currently implemented for supporting balanced three-phase grids with their extensive low-voltage grids rather than poles for every four houses - as seen in Europe and large shares of the world.
That said, grid calculation on 'North American grids' abides to the same rule-set as calculating other grid setups. Adapting / reconfiguring Volue Grid Calculator for your needs is feasible given the right business case.
With such grid calculation capabilities offered directly to your GIS users valuable business intelligence is democratized and your calculation experts are offloaded to focus on more complex calculations.
Jens Dalsgaard
Principal Product Owner
Power Grid, V O L U E
jens.dalsgaard&@volue.com
Volue Technology Denmark A/S
Alfred Nobels Vej 27
9220 Aalborg Øst, Denmark
volue.com
