I would like know more information about how UN support the length of edgeobject like "the linear service laterals" based on the description of this ufficial documentation example.
Original link:
https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/connectivity.htm
Is the lenght of edgeobject based on the distance beetween the two waterjunction? Where I can find this value?
thank you
Giuseppe
To add to Mike's response...
If you were to run an aggregated geometry trace using the Synthesize Geometries parameter, this would also return aggregated geometry for the edge object or association from which you could derive length.
