junction-edge from/to connectivity and relative distance
1500
06-18-2024 06:37 AM
gpgisandsky
I would like know more information about how UN support the length of edgeobject like "the linear service laterals" based on the description of this ufficial documentation example.
Original link:
https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/connectivity.htm
Is the lenght of edgeobject based on the distance beetween the two waterjunction? Where I can find this value?
thank you
Giuseppe
2 Solutions
MikeMillerGIS
Esri Frequent Contributor
You would add a field to the edge object class and store a value of the length. If you want the system to calculate the length, just use a line.
JonDeRose
To add to Mike's response...
If you were to run an aggregated geometry trace using the Synthesize Geometries parameter, this would also return aggregated geometry for the edge object or association from which you could derive length.
MikeMillerGIS
JonDeRose
