Isolation Trace Filter Barriers to not include open inoperable valves
4286
5
08-24-2022 12:13 PM
LoriRadunzel-Davis
I am attempting to set up an isolation trace to use if there is a line break in our water network.  I have it working as desired with the following exception, I would like a valve that is not operable and open to NOT be a barrier, since it would not be able to be closed to isolate a leak.  I have set the Filter barriers to include Operable is equal to True, but when I am testing a valve that has Operable = False keeps getting selected.  This is true also if I specify Operable = True AND Category = Isolating.  Is there some way to do this or is that fact that valves are all designated as Isolating or something else preventing this?
Condition barriers include Device Status = Closed or Lifecycle Status not equal to In Service, neither of which apply to this particular valve I'm testing with.
Thanks!
RobertKrisher
I was able to get this to work by adding two filter barriers (operable = true and category=isolating), the key thing was I needed to set the "combine using" to be AND, otherwise the inoperable valve was still being considered because of its isolating category.
RobertKrisher
LoriRadunzel-Davis
Thank you for your reply Robert.  I had tried that repeatedly without the correct result.  After your reply I did again with both Pro 2.7.0 and Pro 2.6.7 with no success.  I am using UN version 4.  I noticed you had some different selection boxes, so maybe the version I am using is having an influence.
jclarke
You could try the Naperville UN Water Distribution solution to see if it works for you with your setup. It has Operable as a network attribute so it should be a quick test. You would need to download the older one compatible with Pro 2.6 and UN schema 4. I think this is the one.
Beyond that I would suggest trying a simpler trace with just Operable as a filter barrier - just to learn where it might be going wrong.
LoriRadunzel-Davis
Thank you for your suggestion.  I didn't think of trying it on a different dataset.  I had a copy of the Naperville data downloaded already.  It worked on that.  I found that having to uncheck the Validate Consistency option was causing the problem.  I have to uncheck it to work on our water system, since there are almost always dirty areas with so many users collecting and editing data.
RobertKrisher
Glad to hear it worked! Strategies for keeping dirty areas in check is a good topic for a different thread 🙂
