Insert record to a Utility Network feature class from PostgreSQL
1117
08-29-2024 09:34 AM
rohanrajan_hms
I have a working Utility Network. I want to add features / Assets / records to the UN feature classes directly from postgresql. Is it possible? If Yes, does it work similar to the append operation in the ArcGIS environment?
Any insight on this would be much appreciated.
Thank You
RobertKrisher
This is not supported and doing so will corrupt your data because you will be bypassing the utility network which manages system-maintained fields and tracks edits made to the topology.
For a discussion of approved methods for loading/manipulating data (Python, Rest, etc) read this series of articles: Journey to the Utility Network: Integrations Overview (esri.com)
RobertKrisher
