Importing Geometric network validation rules to the Utility network
1160
04-11-2025 12:19 AM
angiexx1
I have geometric network with 7 tables of rules for checking QA/QC, i want it to use that in the UN, i have found Import Attribute rules tool for bulk uploading, my question is, do i have to generate attribute rules for each and every row? or can i do that in a single go?
RobertKrisher
Read the Get started with ArcGIS Data Reviewer page to learn how to create your own set of configurable checks to assist/automate data validation. If you have any questions about how to best configure different checks, I recommend you post them on the ArcGIS Data Reviewer page of the community.
MikeMillerGIS
Esri Frequent Contributor
I am not familiar with the ArcMap process that uses that table for validation.   What process/tool uses it?
My suggestion would be to look at Data Reviewer and recreate these these validation checks.
angiexx1
Okay in the geometric network all my rules are in the format of a tables so , so how can i do validation checks in the data reviewer? so i dont need to do in the attribute validation?
RobertKrisher
