import association through the service
2424
9
04-03-2025 02:12 AM
gpgisandsky
I have AGS11.3 + UN v7 on Oracle DB. I need import un association. I have csv/excel based required by tool Import Association. Import Association work fine on file geodatabase un.
CSV example:
ASSOCIATIONTYPE,FROMFEATURECLASS,FROMASSETGROUP,FROMASSETTYPE,FROMGLOBALID,FROMTERMINAL,TOFEATURECLASS,TOASSETGROUP,TOASSETTYPE,TOGLOBALID,TOTERMINAL,ISCONTENTVISIBLE,PERCENTALONG
Containment,StructureJunction,Pozzetti,Cameretta di ispezione,{450CCDC5-24AA-4018-9001-793E856513CB},,AqDevice,Valvole,Valvola di rete,{5679CD23-D8EC-44DA-95C5-87632E35D40E} ,,False,
Now, I need import association directly on  un feature service. is there a py script/tool that I can use?
It's possible (https://developers.arcgis.com/rest/services-reference/enterprise/appendix-working-with-the-feature-s...) and I would like use a *.py script within pro to do this operation.
Thank you
gis_KIWI4
MVP Regular Contributor
In the payload you pasted in questions there seems to be an additional space.
'TOGLOBALID': '{5679CD23-D8EC-44DA-95C5-87632E35D40E} '
There is a space at the end of the TOGLOBALID.
It may be worth checking if the csv has a rogue space at the end of the TOGLOBALID that the code might be ingesting.
PS - The format of the globalIDs is correct.
MikeMillerGIS
Esri Frequent Contributor
The association table supports ApplyEdits, so you just need to craft the apply edits payload just like editing any other feature service/table.
The association table is always layer id 500001
gpgisandsky
hi @MikeMillerGIS ,
i tried this:
import arcpy
import csv
import json
import requests
#Acqua Device (ID: 1)    "sourceId": 9,
#Acqua Junction (ID: 2)    "sourceId": 12,
#Structure Junction (ID: 3)    "sourceId": 4,
# Configurazione
portalUrl = "https://xyz/portal"
username = 'xyz'
password = "xyz"
csv_path = r"C:\ArcGIS\26_xxx_UN\Creazione_UtilityNetwork\PRO prj\File_GDB\Association_xxx_2025_04_01_ore1811_DEVICE.csv"
# Funzione per ottenere il token se necessario
def get_token():
    token = generateToken(username, password, portalUrl)
    return token
def generateToken(username, password, portalUrl😞
    # Retrieves a token to be used with API requests.
    headers = {'content-type': 'application/x-www-form-urlencoded'}
    parameters = {'username': username,
                  'password': password,
                  'client': 'referer',
                  'referer': portalUrl,
                  'expiration': 60,
                  'f': 'json'}
    url = portalUrl + '/sharing/rest/generateToken?'
    response = requests.post(url, data=parameters, headers=headers)
    try:
        jsonResponse = response.json()
        if 'token' in jsonResponse:
            return jsonResponse['token']
        elif 'error' in jsonResponse:
            print(jsonResponse['error']['message'])
            for detail in jsonResponse['error']['details']:
                print(detail)
    except ValueError:
        print('An unspecified error occurred.')
        print(ValueError)
# Leggere il CSV e creare le associazioni
associations = []
with open(csv_path, 'r', encoding='utf-8') as file:
    reader = csv.reader(file)
    header = next(reader)  # Legge l'intestazione
    for row in reader:
        if len(row) != 13:
            print(f"Errore: Riga non conforme -> {row}")
            continue
        association = {
            "attributes": {
            "ASSOCIATIONTYPE" : 2,
            #"ISCONTENTVISIBLE" : <0|1>,  // optional: false, true
            "FROMNETWORKSOURCEID" : 4,
            "FROMGLOBALID" : row[4],
            #"FROMTERMINALID" : <long>,   // optional
            "TONETWORKSOURCEID" : 9,
            "TOGLOBALID" : row[9],
            #"TOTERMINALID" : <long>,      // optional
            #"PERCENTALONG" : <float>       // optional
            "ISCONTENTVISIBLE" : 0
        associations.append(association)
# Invia le associazioni al Feature Service
payload = [
        "id": 500001,  # Modifica con l'ID corretto del layer delle associazioni
        "adds": associations
# Funzione per inviare modifiche al Feature Service
def apply_edits(payload😞
    url = f"{feature_service_url}/applyEdits"
    data = {"geodatabaseVersionName" : "sde.DEFAULT", "useGlobalIds" : "true", "f": "json",   "token": get_token(), "edits": json.dumps(payload)}
    response = requests.post(url, data=data)
    return response.json()
# Esegui l'importazione
result = apply_edits(payload)
print("Risultato dell'importazione:", result)
# Miglioramento: Gestione degli errori per il risultato
if 'error' in result:
    print("association:",association)
    print("Errore durante l'importazione:", result['error'])
else:
    print("Importazione completata con successo.")
but I had the following error:
Errore durante l'importazione: {'code': 400, 'extendedCode': -2147219118, 'message': 'Unable to complete operation.', 'details': ['Internal error while adding containment association. A requested row object could not be located.']}
association content is:
association: {'attributes': {'ASSOCIATIONTYPE': 2, 'FROMNETWORKSOURCEID': 4, 'FROMGLOBALID': '{450CCDC5-24AA-4018-9001-793E856513CB}', 'TONETWORKSOURCEID': 9, 'TOGLOBALID': '{5679CD23-D8EC-44DA-95C5-87632E35D40E} ', 'ISCONTENTVISIBLE': 0}}
what could be wrong?
MikeMillerGIS
Could be the format of the globalids.  Do they have {}? Can you use fiddler or something and share what the payload looks like?  Compare that to the payload when you make association in Pro.
The other thought I had, have you tried the append gp tool?  You can make a table view from the url and call change version(gp) on it.
gpgisandsky
The other thought I had, have you tried the append gp tool? No, append gp tool works on
service?
MikeMillerGIS
GP Append does work with services
gis_KIWI4
gp2014
hi, there is a additional space. I'll try to send the request without space. thank you
gis_KIWI4
Did removing the space fix it? @gp2014  @gpgisandsky ?
gp2014
Hi @gis_KIWI4 , Im waiting to restore the db. I'll try next day. thank you
