I NEED HELP TO CLEAN THOSE MESSAGES IN ERROR INSPECTOR AND DIRTY AREA
2619
07-10-2023 12:14 AM
RomuldKiobya
Hii Community
Review attached documents below, I get those message "The geometry for Network Feature is empty" .  Always after doing the appending data, there are data that out of service boundary are rejected.  At those locations of rejected data cause that message to come at dirty Area and error inspector. I need to remove/clean on attribute of dirty area and error inspector.  and remove at those boxes from the map.
But remember when I validate  the pop up message come 'vallidation succesfully' or no 'dirty Area'
RobertKrisher
Because this is specific to the utility network I am going to move this to the Utility Network channel.
RobertKrisher
Because these features have no geometry, the utility network has to create dirty areas for them somewhere. In these instances, it chooses the lower-left corner of the extent of your service territory. Once you correct the underlying features by either creating a geometry or deleting them you should validate your network topology with the full extent of your dataset to clear the error.
