Error with 'Asset Package to Geodatabase' Tool in ArcGIS Pro 3.4
2101
03-31-2025 03:43 AM
MarianoDiNapoli
Hello everyone,
I'm experiencing an issue with the 'Asset Package to Geodatabase' tool while transferring data from the Asset Package to the Utility Network. Specifically, the tool works fine when running without the D_RENAME table, but it fails when we choose the option to translate assets using the D_RENAME table, even though the table itself is correct.
I’d like to ask if anyone else has encountered this issue or if it could be a bug in version 3.4 of ArcGIS Pro. I also want to point out that the same tool works correctly in ArcGIS Pro version 3.3.2, even with the D_RENAME table used for asset translation.
Mariano
MikeMillerGIS
Esri Frequent Contributor
That asset package is not valid, it looks like all the A_ and B_ and D_ tables have been truncated.  We need the values in those tables
PatrickGCowan
What is the error message that you are getting when it fails?
If you want to send us a schema only version of the asset package, we can take a look at it. You can direct message it to me.
MarianoDiNapoli
Hi Patrick,
Thank you for your availability.
I am attaching the requested material.
Mariano
MikeMillerGIS
PatrickGCowan
We were able to reproduce the issue. This issue will be fixed with the release of Pro 3.5. I would suggest either using 3.3 for now, or using 3.5 when it is released.
