ERROR 160189: The spatial index grid size is invalid
10335
11
01-26-2022 03:59 AM
GIS_Solutions
Hi everybody,
I get this error when I run the update subnetwork tool.
There is no solution for content.
Anyone have any ideas?
GIS_Solutions
Yes im working on file gdb.
When I deleted the spatial index and started the Update Subnetwork tool again, it did not give an error.
Thank you @JonDeRose @Anonymous User
DanPatterson
MVP Esteemed Contributor
There are potential solutions in the error message
160189: The spatial index grid size is invalid. <value>—ArcGIS Pro | Documentation
Did you use this?
Add Spatial Index (Data Management)—ArcGIS Pro | Documentation
did you try to see if updating it works
... sort of retired...
GIS_Solutions
yes i saw that but it didn't work
by Anonymous User
Not applicable
Perhaps you could try deleting and rebuilding the index for the Network layer that contains the subnetwork lines?
GIS_Solutions
Hi @Anonymous User
Sorry i coud not  understand what you said. Because The subnetwork layer is not an erasable layer.
I wonder Did i misunderstand what you want to say?
JonDeRose
@GIS_Solutions Are you running into this issue with UN on File Geodatabase or Enterprise? I beleive this is file... The issue is likely with the index on SubnetLine.  Could be a result of the current update adding a very large subnetwork to a class previously populated with much smaller features.  Agree with @Anonymous User above that dropping the spatial index, running Update Subnetwork, and then recreating the index should allow you to move past this.
GIS_Solutions
by Anonymous User
Not applicable
Sorry I probably needed to make this clearer--I think in the Pro Template for the solution the group layer is called Water or Electric Network but the underlying feature class is subnet line.  I would drop/add the spatial index on that layer.
Boniface2023
Hi when I'm trying to update subnetwork of electric distribution in ArcGIS pro i face the error which say "SPATIAL INDEX GRID SIZE IS INVALID" please help me on how to solve this error because i have deadline and i don't know what to do to clear this issue
Jon_D
@Boniface2023 Did the above note about dropping the spatial index on the SubnetLine not enable your update to proceed?
