Domain Clean-up Post Migrate to UN Tool
610
02-17-2026 11:06 AM
Bloper
Hello, I have been working on running our Utilities (water, sewer, storm) through the Migrate to Utility Network.
I am at the stage of having the UN created in a FGDB, but our team are taking advantage of the data layers being in a FGDB to do a little more 'clean-up' on the schema with the legacy data we're bringing into the UN BEFORE we package everything up to an EGDB and not deal with table schema locks.
QUESTION: Post running the layers through the Migrate tool, I noticed that for DOMAINs, there are names that support AssetType, ie. 'AssetType_SewerDevice_......', but also noticed that my original legacy domain names are saved as well and named similar to the following: 'Orig_Type_Sanitary_Sewer_....'.
Can I delete these 'Orig_Type_Sanitary_Sewer_....' Domain names after the Migrate tool has run and AssetTypes are established?
Screenshot for reference of my Domain table for Sewer:
MikeMillerGIS
Esri Frequent Contributor
Sure, but you probably need to remove their assignment or delete the field they are assigned to.
MikeMillerGIS
Bloper
Thank you for your feedback!
Excellent point and good house-cleaning recommendation. I have verified that my 'Legacy' domains are not assigned to any subtypes. They have zero assignments.
The new 'Asset_Type' domain values created by the Migrate to UN tool have been assigned to the correct assets.
Thanks again for your reply.
