Domain changes to Asset Package
1260
08-11-2023 07:15 AM
BryanMay531
I want to add values to domains in the Utility Network Foundation Asset Package.  Can I just modify domains directly in the asset package?  Or is it necessary to use the D_Rename Table?
TobeyKane-Seitz
For adding values, you can edit directly in the asset package. Here's a helpful post about the D_rename table https://community.esri.com/t5/arcgis-utility-network-blog/utility-network-foundation-solutions-chang...
TobeyKane-Seitz
BryanMay531
Thank You!  So is it ok to make changes to the asset package without using the D_Rename table?
