Deletion of structural attachment association in bulk
839
12-05-2022 04:03 AM
GIS_Solutions
I have defined Structure attachment rule between Structure Junction feature and Electrical Junction feature.
I created about 40,000 attachments using the Append tool. How can I remove these attachments from data in bulk.
//$feature is an ElectricJunction
var sjFeatureSet = FeatureSetByname($datastore, "StructureJunction", ["objectid"] ,false)
// Asset Group	101-102-103-104-105
// Asset Type	111-112-120-121-122-130-131-132-133-134-381-382-383-470-471-473-474-475-476-477-478-479-480-481-482
var polesFeatureSet = Filter(sjFeatureSet, "ASSETGROUP in (101,102,103,104,105) AND ASSETTYPE in (111,112,120,121,122,130,131,132,133,134,381,382,383,470,471,473,474,475,476,477,478,479,480,481,482)")
//buffer
var g = buffer($feature, 0)
var intersectedPoles = Intersects(polesFeatureSet,g)
if (count(intersectedPoles) == 0)
  return $feature.Note;
var pole = first(intersectedPoles)
return {
         "result": $feature.Note,
         "edit":
                 "className": "structurejunction",
                 "updates":
                   "objectID": pole.objectid,
                   "associationType": 'structure'
jclarke
You can delete associations via Arcade e.g. https://community.esri.com/t5/arcgis-utility-network-questions/create-an-attribute-rule-to-delete-th...
Could you combine this with a batch calculation attribute rule?
