DBMS table not found [42S02:[Microsoft][ODBC Driver 17 for SQL Server][SQL Server]Invalid object name 'GDO.ElnetUN'.] [GDO.ElnetUN]
200
2 weeks ago
MalteSørensen
I have installed a new PC with ArcGIS Pro 3.5.4 and whenever I try to create a new Utility Network feature service with Share As Web Map I get the following error for the Utility Network:
I can run the exact same process with same database and portal on other machines and it publishes without any errors. I have also tried reinstalling both ArcGIS Pro and ODBC drivers, but get the same result.
Any ideas as to why i get this error and how it can be fixed?
RobertKrisher
Is the connection file using the credentials of the data owner?
It sounds like there may be a difference in the connection files between the machines. If you copy one of the connection files from the other machines to this one, does it work?
MalteSørensen
Hi Robert,
I am using same connection file on both machines, which is using the credentials of  the data owner, so I am guessing it has something to do with the installation.
It only seems to have issues with the UtilityNetwork layer, as I can publish maps not containing this without issues.
