Communication Model V1 - Subnetwork Configuration Is Missing
9929
16
11-20-2020 12:22 AM
JürgenBiendara
I am trying to set up "CommunicationsDataManagementForArcGISEnterpriseV1" but get attached error during application of asset package.
Is this problem known and is there a solution/fix to it?
Thanks and best regards,
Jürgen
PaulLeBlanc1
Can you try the steps from https://solutions.arcgis.com/utilities/help/utility-network-automation/get-started/frequently-asked-... ? I'm not sure why the refresh isn't showing it to you.
JürgenBiendara
Unfortunately, that does not resolve the problem:
(arcgispro-py3-clone1) C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone1>conda install -c esri untools --insecure
Fetching package metadata .............
Solving package specifications: .
Warning: 2 possible package resolutions (only showing differing packages):
- defaults::parso-0.8.0-py_0, esri::jedi-0.16.0-py36_0
- defaults::parso-0.7.0-py_0, esri::jedi-0.17.2-py36_0
Package plan for installation in environment C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone1:
The following packages will be UPDATED:
arcgis: 1.8.3-py36_1665 esri --> 1.8.3-py36_1668 esri
pandas: 1.0.5-py36h47e9c7a_0 --> 1.1.3-py36ha925a31_0
untools: 2.6.0-py36_1 esri --> 2.6.2-py36_0 esri
Proceed ([y]/n)? y
Disabling notebook extension arcgis/extension...
- Validating: ok
Uninstalling arcgis arcgis/extension
Removing: C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone1\share\jupyter\nbextensions\arcgis
ERROR conda.core.link:_execute_actions(337): An error occurred while installing package 'defaults::pandas-1.1.3-py36ha925a31_0'.
CondaError: Cannot link a source that does not exist. C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgs\pandas-1.1.3-py36ha925a31_0\Lib\site-packages\pandas-1.1.3.dist-info\INSTALLER
Attempting to roll back.
JürgenBiendara
Hi Paul,
This log-file documents my unsuccessful attempt to upgrade the untools via Python Prompt. Does that give any clue?
Regards,
Jürgen
(arcgispro-py3-clone) C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone>conda install -c esri untools --insecure --no-pin -v
Package plan for installation in environment C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone:
Proceed ([y]/n)? y
===> UNLINKING PACKAGE: defaults::pandas-1.0.5-py36h47e9c7a_0 <===
prefix=C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone
===> UNLINKING PACKAGE: esri::untools-2.6.0-py36_1 <===
===> LINKING PACKAGE: defaults::pandas-1.1.3-py36ha925a31_0 <===
source=C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgs\pandas-1.1.3-py36ha925a31_0
===> REVERSING PACKAGE LINK: defaults::pandas-1.1.3-py36ha925a31_0 <===
===> REVERSING PACKAGE UNLINK: esri::untools-2.6.0-py36_1 <===
===> REVERSING PACKAGE UNLINK: defaults::pandas-1.0.5-py36h47e9c7a_0 <===
An unexpected error has occurred.
Please consider posting the following information to the
conda GitHub issue tracker at:
https://github.com/conda/conda/issues
Current conda install:
platform : win-64
conda version : 4.3.27
conda is private : False
conda-env version : 4.3.27
conda-build version : 3.18.9
python version : 3.6.8.final.0
requests version : 2.22.0
root environment : C:\Program Files\ArcGIS\Pro\bin\Python (writable)
default environment : C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone
envs directories : C:\Program Files\ArcGIS\Pro\bin\Python\envs
C:\Users\j.biendara\.conda\envs
package cache : C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgs
C:\Program Files\ArcGIS\Pro\bin\Python\pkgs
channel URLs : https://conda.anaconda.org/esri/win-64
https://conda.anaconda.org/esri/noarch
https://repo.anaconda.com/pkgs/main/win-64
https://repo.anaconda.com/pkgs/main/noarch
https://repo.anaconda.com/pkgs/free/win-64
https://repo.anaconda.com/pkgs/free/noarch
https://repo.anaconda.com/pkgs/r/win-64
https://repo.anaconda.com/pkgs/r/noarch
https://repo.anaconda.com/pkgs/msys2/win-64
https://repo.anaconda.com/pkgs/msys2/noarch
config file : C:\Program Files\ArcGIS\Pro\bin\Python\.condarc
netrc file : None
offline mode : False
user-agent : conda/4.3.27 requests/2.22.0 CPython/3.6.8 Windows/10 Windows/10.0.17763
administrator : True
`$ C:\Program Files\ArcGIS\Pro\bin\Python\Scripts\conda install -c esri untools --insecure --no-pin -v`
File "conda\core\link.py", line 326, in _execute_actions
File "conda\core\path_actions.py", line 230, in execute
File "conda\gateways\disk\create.py", line 246, in create_link
conda.CondaError: Cannot link a source that does not exist. C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgs\pandas-1.1.3-py36ha925a31_0\Lib\site-packages\pandas-1.1.3.dist-info\INSTALLER
During handling of the above exception, another exception occurred:
File "conda\core\link.py", line 281, in execute
File "conda\core\link.py", line 344, in _execute_actions
conda.CondaMultiError: Cannot link a source that does not exist. C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgs\pandas-1.1.3-py36ha925a31_0\Lib\site-packages\pandas-1.1.3.dist-info\INSTALLER
File "conda\exceptions.py", line 641, in conda_exception_handler
File "conda\cli\main.py", line 144, in _main
File "conda\cli\main_install.py", line 80, in execute
File "conda\cli\install.py", line 329, in install
File "conda\plan.py", line 830, in execute_actions
File "conda\instructions.py", line 247, in execute_instructions
File "conda\instructions.py", line 108, in UNLINKLINKTRANSACTION_CMD
File "conda\core\link.py", line 297, in execute
JürgenBiendara
Hi Paul,
With the help from Esri support (see case #02696389) we figured out that the problem was caused by a corrupted installation of the "pandas 1.1.3" package. Today, in another attempt to upgrade the untools, ArcGIS Pro installed "pandas 1.1.5" sucessfully and after that also "untools 2.6.2". Right now, I am applying the asset package of the Communication Data Management and it seems to be running successfully as well.
Best regards,
Jürgen
JürgenBiendara
Hi Michael,
Did you have the time and opportunity to look into this?
Meanwhile, I made another test with a new download of the Communication Data Management model, the result was the same.
Thank you very much, best regards,
Jürgen
by Anonymous User
Not applicable
Hi JürgenBiendara,
I faced the same issue with applying the asset package. The only way I could get it to work is to delete the conditional barrier rules from the table.
See the attached image. If you remove all conditional barriers it will apply the asset package, but you may need to add them back in manually after you apply it
JürgenBiendara
Hi Matt (hope that's correct)
Thanks for sharing your observations. Since it is not only me that is facing this problem I assume that the problem is related to either the asset package or to the tools that are delivered by Esri. Instead of manipulating the asset package on my own (as you suggest) I would expect Esri to investigate the root cause and come up with an official solution or fix.
Anyone from the Esri solutions team: Please let me know what to expect and how to continue. Thank you.
Best regards,
Jürgen
