avoid system junction and rules
987
01-11-2024 03:08 AM
gpgisandsky
in my UN by Esri defalut when I edit two edge elements share the same endpoint and have the same Asset group and Asset type a system junction is created.
***reference**
https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/feature-restrictions.htm
"If two edge elements share the same endpoint and have the same Asset group and Asset type, these features can connect without a user-defined intermediate junction or network rule. In this situation, a system junction is created and connectivity is established when the network topology is validated or enabled."
My requirement is:
- avoid that two edge elements share the same endpoint and have the same Asset group and Asset type are considered valid.
- two edge elements that share the same endpoint and have the same Asset group and Asset type must be always connected by a junction or a device
- avoid always system junction beetween two edge elements
How can I set these rules?
gpgisandsky
@MikeMillerGIS any idea?
MikeMillerGIS
Esri Frequent Contributor
Cant make a rule, but could use the system junctions to build some kind of report.
