Hello @AlixVezina
Is there a way to assign a Named Trace Configuration to the utility network Trace widget within experience builder portal v11.3? I have a simplistic app that uses a map with only a single names trace in it. Seems silly for the user to have to pick this one value...
Not in Experience Builder. But if you build an app using the Maps SDK for JavaScript, you can preset the trace type by defining the selectedTraces property.
cc @RichRuh
cc @RichRuh
