Apply Assets Package Error
3800
7
07-25-2023 04:22 AM
FaisalAl-Yaseein
Hello Esri Community,
I hope this post finds you well. I am facing a problem with Utility Network while working on the water utilities data for Mosul City. I have successfully migrated the data using data loading tools to the water utilities foundation schema. After this, I staged the water utilities, but when I attempted to apply the assets package from the toolbox, an unexpected error occurred, hindering further progress.
I would greatly appreciate any insights or suggestions on why this error might be occurring and how I can overcome it. If anyone has encountered a similar problem or knows potential solutions, your guidance would be immensely valuable.
The error message I encountered is as follows:
Apply Asset Package
Parameters
Asset Package C:\MSc\MSc_Thesis_GIS\Project\ArcGISProject\MSC_Mosul_Utility_project\WaterDistribution_AssetPackage_Change.gdb
Domain Networks to apply Structure;Water
Input Utility Network C:\MSc\MSc_Thesis_GIS\Project\ArcGISProject\MSC_Mosul_Utility_project\WaterDistribution_AssetPackage_Change.gdb\Mosul_Utility_Network_1\Mosul_Utility_Network
Load data INCLUDE_DATA
Calculate Spatial Index and Analyze ANALYZE
Output Utility Network
Configurations to apply Attachments;'Isolation Tier';'DMA Tier';'Pressure Tier';'Cathodic Protection Tier'
Rename using
Post Process NO_POST_PROCESS
Messages
Start Time: Tuesday, July 25, 2023 2:20:16 PM
ArcGIS Pro 3.1.2.41833
untools 3.1.0
Executing from ArcGIS Pro, 6 map(s), activeMap = True
Parallel processing enabled: 6
Asset Package schema version: 2.7
A python error occurred.
EXCEPTION
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\common\wrappers.py", line 159, in wrapper
f = func(*args, **kwargs)
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\gptools\tools.py", line 609, in run
ap = ap_constructor(
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\gptools\tools.py", line 53, in ap_constructor
ap = AssetPackage(
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\utility_network\ap.py", line 87, in __init__
self._properties: dict = self._initialize(kwargs.pop("cache", None), **kwargs)
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\common\wrappers.py", line 425, in wrapper
result = func(*args, **kwargs)
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\utility_network\ap.py", line 123, in _initialize
data = self._validation.validate_all(asset_package=self)
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\validation\validate.py", line 1117, in validate_all
data = self._virtualize_un(asset_package)
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\validation\validate.py", line 1029, in _virtualize_un
xml_un = s.main()
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\utils\ap_to_xml.py", line 1709, in main
self.add_domain_networks()
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\utils\ap_to_xml.py", line 715, in add_domain_networks
self.set_values(
File "C:\Users\A971891\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\utils\ap_to_xml.py", line 338, in set_values
element.find(k).text = str(v)
AttributeError: 'NoneType' object has no attribute 'text'
Failed to execute (AssetPackageToUtilityNetwork).
Failed at Tuesday, July 25, 2023 2:20:42 PM (Elapsed Time: 25.48 seconds)
MikeMillerGIS
Esri Frequent Contributor
It looks like there is a UN in the Asset Package.  There are known issues with this.  You need to remove the UN and the FeatureDataset.
MikeMillerGIS
Could you share a schema only asset package(run change Asset Package Spatial Reference) and the ap_workspace folder that was created?  We do not need data.
FaisalAl-Yaseein
I already did for the target schema, which result in new gdb with the same schema and no data with the projection that we need. when I run the staging of the utility network, it produced a new data set. the next step from references is to apply assets package which its stopped me
MikeMillerGIS
Ariggs
Hi Mike,
I'm also trying to run Apply Asset Package with pre-existing data. I exported my Utility Network to an asset package, modified that asset package with the D_configurations and D_rename tables, and am following the Solutions workflow for creating a new enterprise geodatabase and running Stage Asset Package and Apply Asset Package. Apply Asset Package is failing with the following error:
 Is there some other workflow I should be following or step I have missed in order to run Apply Asset Package with an existing UN in the asset package? Or some other method of creating a new Utility Network with the data of an old one?
MikeMillerGIS
Can you post a screen shot of the error?  What version of ArcGIS Pro and untools are you using?
IvanDImitrov
How is that - to remove UN?
If we want to apply the asset package to a .GDB, we need some features, right?
MikeMillerGIS
The asset package A_, B_ table represent all the properties of the Utility Network and are used to construct one.  There should not be a utility network in the asset package.
