Apply Asset Package FAILED TO EXECUTE
1567
7
05-22-2025 09:10 AM
Vikranth_Madeppa
I am trying to Apply asset package and I keep getting this error. Have tried multiple times now. Any insights on this would be much appreciated.
MikeMillerGIS
Esri Frequent Contributor
What are your parameters?  What is your target GDB type?  Have you tried Asset Package to Geodatabase?
Vikranth_Madeppa
Hi Mike,
I have not tried asset package to GDB . Can you explain further how I can use this and apply to Utility network ?
Thanks & Regards,
Vikranth_Madeppa
I am doing this process in a FIle GDB , created a UN in file GDB and using Apply asset package to this UN.
I am always getting this Domain Network error.
Is there a way to check the difference in the domains of my asset package and UN, so that I can find out what the issue is and fix it ?
JoaquinMadrid1
Mike's recommendation to run AP2GDB before going through the whole Apply to EGDB is the way to go. We have it as part of our standard process. You catch a lot of stuff running AP2GDB without "polluting" the E-GDB. And then you easily clean up the AP and try again.
This minimal overhead saves a lot of time and headaches. Thank you, Mike,.
MikeMillerGIS
Try Asset Package to Geodatabase, it creates a new geodatabase, stages the UN and then applies the asset package.  This will eliminate some variables.
Vikranth_Madeppa
Thank you very much .
Asset Package to Geodatabase worked. But I did get some error.
Its an error for subtypes (Structure Boundary , Water Line, WaterDevice_1_Fields-Subtypes-CV.xml:1195)
Just trying to figure out the subtype fields and the difference in schema.
MikeMillerGIS
I would try this
Start a brand new ArcGIS Pro sessions
Do not add any maps
Run the Asset Package to Geodatabase
