Apply Asset Package error "Required dataset is missing"
1216
09-18-2024 11:53 AM
SusanONeill1
After successfully creating a Sewer UN (in a file geodatabase at this point), I am working on the Water Network.  When running the Apply Asset Package, I get the error "Required dataset is missing".  I've compared every layer and table in my Asset database against the ESRI Water Utility Network Essentials and I can't figure out what dataset is missing.  Is there any way to get more detail on what dataset is causing the error?  Thanks.
I am using UN tools 3.3.2 and ArcPro 3.3.1.52636
MikeMillerGIS
Esri Frequent Contributor
That error is only triggered when you do not have a featuredataset called "UtilityNetwork"
MikeMillerGIS
SusanONeill1
Thanks.  to differentiate from the Sewer data, I had named the new dataset "WaterUtilityNetwork".  Now that I've changed it, it's working.
