Accessibility to Electricity Asset Package
1354
03-09-2023 07:26 AM
Acharya
Hello Everyone,
I am trying to work with the electricity asset package from Esri. I am trying to stage Utility network in enterprise database and share Utility network in ArcGIS Enterprise as Feature Service.
I have downloaded ElectricUtilityNetworkFoundation from ArcGIS Solutions. I have opened the ArcGIS Pro project, I can see Utility Network in Pro. However, Electric Asset Package is empty . Hence, I can not stage UN in sde (as Service Territory is not available) and also can not work further with enterprise database.
Has anyone worked with this asset package and shared its UN in portal as Feature Layer?
I am trying to build a web application with Utility Network. It would be a great help.
Thank you so much in advance.
MikeMillerGIS
Esri Frequent Contributor
The asset package is shipped without data and a spatial reference.  You need to run Change Asset Package Spatial reference and then append/sketch in your service area polygon.  If you want to use the sample data, you can export an asset package from the Utility Network we ship.
Acharya
It worked. Thanks a lot. I could export an asset package.
I also added D_CONFIGURATION and D_RENAME tables and ran Apply Asset package. However, I get the following error:
Is there some problems in table or do I need further steps for exporting asset package?
