Map Notes Issue
583
07-29-2019 02:33 AM
HatimAmiji
I am trying to make a map and have individual map notes for specific data. However, when I save the map and view the published verion, clicking on some map notes causes a weird string of text to show up. For example, this shows up on one of them: "<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->" and another shows this "<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}--><!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->" Does anyone know what might be causing this; it is not necessarily a problem in a functional sense, but it is really unaesthetic and takes away from what the map note is trying to highlight.
Tags (1)
HeatherSmith
Esri Alum
Hi Hatim,
Could you let us know where you are creating and viewing the map notes? For example, are you creating them in ArcGIS Pro and viewing them in a map you published to ArcGIS Online, or is your workflow something different? Are the weird strings found inside the pop-ups?
Thank you,
Heather
