Thanks Phil, I have a test form that is giving me the following error (TestError.PNG) When I try to input data into the form on our Test Portal
Failed to load data from
External instance "linename" is empty.
External instance "location" is empty.
However the same form, published in the same manner, from Survey 123 Connect works perfectly fine in the AGOL environment.
It seems like the published form on the test portal is not correctly reading the external choices tab (itemsets.csv) when published to our test portal.
Thanks for your help,
Paul
