Web Form Error - An item with the same key has already been added
2135
04-01-2020 12:55 PM
joshahmann
Hi All,
I have published a survey through Connect and have a web app setup to link to the web form. I have the link setup to edit existing data and add records to a related table. I am able to update an existing record and add a related record but if I try to enter two related records I get the following error:
"Failed to submit - An item with the same key has already been added."
Also, if I open a record in the web form that already has a related record and try to edit either the main record or the related record, I get the same error when I hit submit.
The feature class and the related table are linked using a GUID. I have no problem adding related records using my web app, its only Survey123 that fails.
Any help would be much appreciated.
JamesTedrick
Esri Esteemed Contributor
Hi Josh,
Apologies for the delay.  For this scenario, it would be helpful if we had a few more details.  Is this using an existing feature service or a feature service created by Survey123 Connect.  The failure to submit occurs only when there are more than 1 new repeat records, correct?
by Anonymous User
Not applicable
Hi James,
I am also getting this error mine is probably just because I'm editing a data within my repeat table. Is it still not supported in Survey123 web app?
MaryEllen_Perko
Hi.  Did anyone ever get an answer to this?  We're running into the same problem.  Thanks.
