Using Survey123 with a feature layer from ArcGIS Online
3237
05-27-2021 06:10 AM
FrankDay
I am creating a survey that uses a feature layer from ArcGIS online as a base.  I want to display information from the feature layer on my survey for information purposes.  This works fine if the field on the feature layer is one that you type your information in.  The field I am having trouble with is a drop-down in ArcGIS online.  In Survey123, it shows the code, not the label.  How do I get it to show the label, not the code?  I have attached screenshots.
by Anonymous User
Not applicable
Hi @FrankDay,
Can you provide a copy of your xslxform so we can take a closer look? What I am interested to see if what is in your choice list sheet?
Regards,
Phil.
by Anonymous User
Not applicable
Hi @FrankDay,
Regards,
Phil.
FrankDay
I re-created the survey, and this particular situation is fixed.  Thanks for getting back to me.
cschooley
Would you be willing to share how you did it? I would like to do something similar?
Thanks!
