Use pull data function for geolocation
1657
03-28-2021 07:45 AM
jennascheub
I am a high school science teacher that has been conducting frog surveys with my students for several years. I am working on moving data collection to survey123 so that we can visualize data for several established survey locations. I would like to either collect data in the field using survey123 or upload it into survey123 from paper forms.
The issue I'm running into is how to connect the geolocation for pre-established survey locations with all of the rest of the data. I don't want to use the "geolocate" function in survey123 because I want the data to always be tied to an exact lat/long.  If there is an easier way to do this on the front end (survey123) or the backend (ArcGIS online), please let me know!
After making my initial survey123 form I found this video. I was so excited when I successfully created calculation fields and got the lat/long to show up in the Survey123 connect app! However, when I tried saving/publishing the form, I ran into my first problem: the calculated fields didn't show up in the v1 version of my form on the mobile version. Next, I tried saving the form into a v2. I realized there was probably an issue with my v1 because I entered form data before adding the calculation fields.
Frogwatch form v1 https://arcg.is/1efyrX1
Frogwatch form v2 https://arcg.is/4qX4L0
I am currently getting this error message when I try to enter data into the v2 form:
Here is the geolocation file for the survey locations "frog_stops_all"
LATITUDE
LONGITUDE
TITLE
44.62459
-85.7983
2018A_Bush_Rd_1st_south_Gonder_
44.6095
-85.8004
2018B_Bush_Rd_south_of_Bluebird_Ct_
44.60028
-85.8056
2018C_Betsie_River_Rd_west_Pinecone_D
44.61022
-85.8175
2018D_S_Betsie_River_Rd_north_of_Fred
44.62206
-85.8176
2018E_S_Betsie_River_Rd_north_of_Old_
44.63561
-85.7627
01_IPR
44.63732
-85.772
02_Sawmill_Rd_north_
44.63532
-85.7774
03_ICA_Maintenance
44.62967
-85.7867
04_Diamond_Park_Rd
44.63464
-85.7984
05_Gonder_Rd_north_
44.63956
-85.7908
06_Bridge_Lake_area
44.64411
-85.7841
07_Riley_Rd
44.65356
-85.765
08_Commercial_Ave
44.65407
-85.7536
09_Birch_Rd_Tonawanda
44.65225
-85.749
10_end_of_Birch_Rd
bsneller_esrinederland
Hi Jenna, there is a slight difference between the mobile URL and the Browser.
Webform in browser:
https://survey123.arcgis.com/share/850b9bf3bcb542f581ad4829626d9bbc?field:identificatie={identificat...}
Form on mobile
arcgis-survey123://?itemID=850b9bf3bcb542f581ad4829626d9bbc&field:identificatie={identificatie}&center={expression/expr1},{expression/expr0}
Notice especially the & after the id of the mobile form, whereas it is a ? in the browser.
Furthermore i rather use arcade to determine the lat/lon since when the feature can be moved (Geometry($feature).x and.y OR Centroid($feature).x for Polygons)
jennascheub
Thanks for the reply @bsneller_esrinederland !
I somewhat follow the difference in the two URLs that you pointed out but don't understand how to fix it.
Could you point me to a reference for the arcade lat/long information? I'm not a very advanced user and have only done very limited language operations (typically SQL in ArcGIS Online). Or perhaps give me a little more direction about how to incorporate those into the form?
In my original post, I could not figure out how to get photos embedded but the image icon is showing up now. Included are screenshots from Survey123 connect.
Selecting stop in Survey123 connect correctly syncs with lat/long pointSelecting stop in Survey123 connect correctly syncs with lat/long point
pop up box after clicking check box in Survey123 Connectpop up box after clicking check box in Survey123 Connect
