URL Schemes
6248
9
05-07-2021 07:48 AM
EmilySpeck
How do you connect existing feature layer from the web map to survey123 as prepopulated answers to questions?
jcarlson
Correct! Target being the survey field name, source being the field name from the clicked feature.
- Josh Carlson
Kendall County GIS
jcarlson
Check out this blog post, which walks through the process in detail.
- Josh Carlson
Kendall County GIS
EmilySpeck
I do not have a globalid for my feature layer. I have an Objectid
jcarlson
With the recent updates to Survey123, you need a globalID. In your layer's settings, turn on "Enable Sync" to easily add the field. You can turn the setting back off after, if that's a particular concern.
- Josh Carlson
Kendall County GIS
EmilySpeck
I have the globalid on, but it still was not able to work.
This is a brand new survey with no data yet, on arcgis online I have a hosted feature layer that has points that I want to use to prepopulate questions in the survey when my field workers use it.
I am unsure how connect this layer to the survey using url
jcarlson
What does your generated URL look like? It's case-sensitive, so "globalid", "globalID", and "globalId" are not the same. Make sure you're using globalId={globalid}
- Josh Carlson
Kendall County GIS
EmilySpeck
<a href="arcgis-survey123://?itemID=f8bce2f086864f25b685c0eab03e2652&amp;field:globalId={globalid}rel=" nofollow="" target="_blank" ugc"=""><br />Add New Point!</a>
This is the URL that I am using
jcarlson
Ah. For successive URL params, you need to separate them with & characters.
https://some-url?firstParam=something&secondParam=somethingelse&thirdParam=andSoOn
Using that format, make sure each field gets its own &field:fieldname={field} parameter.
And my mistake, I re-read your earlier post. As you are using the features to create new entries in the survey dataset, you don't need to reference the feature's globalID. That's for editing existing features via survey.
To essentially "copy" values from one layer into a totally separate survey, it's a bit simpler.
arcgis-survey123://?itemID=f8bce2f086864f25b685c0eab03e2652&field:target1={sourcel}&field:target2={source2}
- Josh Carlson
Kendall County GIS
EmilySpeck
target1={source1} do you add your own fields instead?
jcarlson
- Josh Carlson
Kendall County GIS
