Upgrade of Survey123 web install from 3.19 to 3.23, reverse proxy no longer works
288
2 weeks ago
JeremyParker1
Upgrade of Survey123 web installation from 3.19 to 3.23 on Linux platform went through without any issues.  We previously set up a reverse proxy using these steps and it worked without any difficulty for 3.19 with Apache:
https://support.esri.com/en-us/knowledge-base/set-up-a-reverse-proxy-for-an-installed-survey123-webs...
However, we are having issues with the reverse proxy on 3.23, where the login screen never loads and there is just a spinning icon.  Accessing the application on the default port 5443 works.  Has anyone experienced this and may have a workaround?
Thanks in advance!
V/r
alison_gou
Hi @JeremyParker1 , this issue has gained our attention very recently. Could you try the following workaround and see if this works for you?
Add the following to your Apache configuration:
<Location "/survey123">
RequestHeader unset Accept-Encoding
AddOutputFilterByType INFLATE;SUBSTITUTE;DEFLATE; text/html text/plain text/xml Substitute 's#"/"#"/survey123/" #ni '
</Location>
Also, can you tell me the version of apache you are using and seeing this error?
Alison
alison_gou
</Location>
Alison
JeremyParker1
Alison, thank you so much for the suggestion and reply!  That helped us to get around the issue! I appreciate the help very much!
V/r
