Hello!
I have a published feature service, which I would like to update using Survey123. I have built the survey. I have configured the feature service and survey according to the documents/video listed below. Right now, if I fill out a survey, it only adds a record instead of updating an existing record. From what I have read I need to enable the inbox and access the records that way. I am having no luck. More information below:
The feature service is a selection of parcels that have to be surveyed. There are 3 fields with parcel information, and the remaining fields are empty. The 3 fields with data were from an existing data source. The data was not added by surveys. The empty fields are associated with a survey questions to be answered.
When I enable the inbox in Survey123 and publish, I can see an inbox in the Survey123 app, but the inbox is empty. According to the video: ArcGIS Survey123: Editing Existing Data with Survey123 - YouTube I should see a list of all of the parcels in the inbox. Is this an older option that is no longer available? Or have I missed something.
I have checked the json for supportsApplyEditsWithGlobalIDs is set to true.
All of the settings, in theory should be correct. I would love some input on this!
Thank you very much!!!!
Cheers,
Jessica
Links I have referenced:
Working with existing Feature Services in ArcGIS Survey123 (esri.com)
How to enable supportsApplyEditsWithGlobalIDs on y... - Esri Community
Prepare for editing existing survey data—ArcGIS Survey123 | Documentation
