All,
I have been tasked with updating a letter generated from a survey with the latest letterhead for our company. The survey was created using Survey 123 Connect by another employee who has left the company. I have searched in Survey 123 Connect and on the web app for the place where I can update the letter header file. I have not found it. I tried googling it and found nothing on the subject. How do I update the header for the generated letter?
L Conner
Solved! Go to Solution.
Assuming they uploaded the file, go to the Surveys Website (https://survey123.arcgis.com/surveys?portalUrl=YOURPORTALHERE)
Then, locate the survey in question and go to the Data tab. E.g.,
Then, go to the reporting tab and click "Manage templates".
You can download the template from there:
Oh, it just crossed my mind. But when you reupload the template, you have TWO options which are worth considering:
