Update survey using data from google sheet
3103
07-27-2023 01:18 PM
DanielLeón81
Hello everyone,
I am developing a form with survey123 connect and I have a doubt. The form needs to receive data that comes from a Google Sheet spreadsheet that is updated from time to time, this data is stored in without coordinates, it only has the addresses with which I hope to run the esri World Geocoding Service to approximate its location and later update with field output the exact location.
My question is: What method do you recommend to integrate the google Sheet spreadsheet with the survey with survey 123 connect?
This is something new for me, as I have usually only created simple forms, I look forward to your recommendations. I am also open to using ArcGIS Field Maps if it is easier to create the workflow there.
Thank you very much in advance.
Regards
DougBrowning
MVP Esteemed Contributor
There is a python package to read google sheets I used once and it was pretty slick.  You could grab the sheet, change to csv, then upload it to AGOL using the Python API.  Make that CSV a linked content in 123 and that should do it.  Make it a bat file on task scheduler and it would be all good.  Just have Pro logged in and it will use its token.
Hope that helps
DougBrowning
Hope that helps
DanielLeón81
Ohh Thaanks
