Update fields 'userdeviceid' and 'start' when working with the inbox
1082
07-01-2024 06:51 AM
corete_potagere
Hi community,
I just realized that the fields meant to return the user device ID, start date, and any field using 'now()' as a calculation don't get updated when editing records through the inbox. Is there a way around this? I assume this is a fairly trivial question, but I couldn't find an answer in the documentation or on this forum.
Many thanks
ZacharySutherby
Hello @corete_potagere
As long as you're not using the `start` or `deviceid` question types and instead are using now() or pulldata("@property", 'deviceId'), you can use `calculationMode=always` in the bind::esri:parameters to have the calculation update in the Inbox.
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
corete_potagere
Thanks a lot Zach, that solved the issue!
