TypeError: Cannot use 'in' operator to search for 'name' in
3631
12
10-26-2022 08:39 AM
Comisión_Estatal_de_Aguasde_Qu
Hi, I have a problem when i try to serch a value in the "filter" . The message is the next:
Help!
Any ideas on this would be appreciated!
Note: Yesteday it worked ok.
ZhifangWang
Hi @Comisión_Estatal_de_Aguasde_Qu ,
Thanks for your feedback.
It seems to be the same issue with https://community.esri.com/t5/arcgis-survey123-questions/filtering-integers-broken-after-october-25-... , which is caused by any number value involved in the filter.
We are looking into the details and will evaluate a hotfix to address this.
Zhifang
ZhifangWang
Zhifang
Thanks!!
GIS_Fox
Hi @ZhifangWang  and @Comisión_Estatal_de_Aguasde_Qu ,
We are expereincing the same type of TypeError on our S123 Form as of this morning. It is a web browser form non Survey123-Connect published, S123 version 3.16, with a repeatable error from using the Contains variable in filtering. Error message is as follows.
Jansen Lyons - Records and GIS Section - Public Works - City of Rio Rancho, NM
JeffLegato1
We are experiencing the same issue.  I found a workaround by setting the filter to be
filter=(1.OBJECTID%20isBetween%20{OBJECTID|%20and%20{OBJECTID})
GeomaticsAecon
Any update on this?  ETA?
DataOfficer
We are experiencing the same issue (see attached image). Worth noting that the filters I am trying to set do not involve numbers.
An error occurred while applying the filter.
TypeError: Cannot use 'in' operator to search for 'name' in [search term here]
ZhifangWang
Hi ALL,
The Survey123 Beta website https://survey123beta.arcgis.com has been updated with the fix to this issue. Can you please help test if the Beta website works for your workflow?
If everything looks good, we will deploy the fix to the production website on 10/31.
Maureen
Works for us too.
DiegoLlamasOlivares
Hello Zhifang,
using that url i do not have the error.
regards,
DLL
