Turn off location capture in Survey123
1492
01-25-2022 10:42 AM
chambersj
Is there a way to turn off or not have to use location capturing in Survey123?
Most of my surveys capture the location information from an existing point on a map.
Not having to use the location services on the mobile phone may extend the battery life.
If there is not a current way to turn off location capturing, can it be considered?
Thank You
Jewell Chambers
IsmaelChivite
Esri Notable Contributor
I am not sure it will make a big difference in terms of battery life, but you can try disabling Survey123 access to location services in your device. I wonder if you can measure any difference.
chambersj
Ismael,
I had thought of that and it can be used that way, but you get this annoying error that you have to cancel every time you start to fill out a survey form.
GarethBaker1
I'd also like to know if there is a way to stop the Survey123 app from attempting to get the location and not bring up that box.
AurelieShapiro
I want people to enter a location on a map - not the location of their device. Is there a way to disable the device location button? They easily get confused, or enter the device location after their went through the trouble of entering the info on the map....
ChrisShuck
We are also experiencing this type of user error.
I could only come up with a workaround, which is to have the user enter Lat and Long into separate text boxes, then have those fields populate a read-only geopoint with a concat() formula.
However, this workaround takes away the convenience of using the map from those users that do know how to use the map properly. We'd rather turn off location services within this particular survey (not for the whole app though).
