Total Results from Dropdown Questions
379
01-03-2023 10:04 AM
RobBeidler66
I was looking to add or total a number from a series of questions. For this survey its grading facilities on a 1-10 bases and I would like to have an autofill at the end that would total the results at the end. I was unsure if this is something that would be possible.
Thanks!
JenniferAcunto
It's quite easy to do this, you just need to use the bind::esri:fieldType column to ensure you are storing the dropdowns as an integer.
See my example XLS.
- Jen
