Time Rounding and Calculations
949
08-26-2024 02:32 PM
ModernElectric
@JamesTedrick @IsmaelChivite @Jim-Moore
@abureaux
I am working on a complex form that I need assistance with. Trying to figure out if this is possible in Survey123 Connect or if I need to research how to do it in Power Automate.
Job Start Time: 8/26/2024 @ 12:25 PM
Leave Job Site: 8/26/2024 @ 4:43 PM
Here is what needs to be done. I've been given a specific rounding table that I need to, somehow, configure into the code:
Job Start Time turns into 13.50 (12:25 pm --> 12.40 --> 12.50)
Leave Job Site turns into 16.75 (4:43 pm --> 16.72 --> 16.75)
From here, need to be able to calculate the difference (16.75 - 12.50 = 4.25 hours worked). ALL ending calculated time on site needs to be 0.00, 0.25, 0.50 or 0.75.
Please help.
Appreciate it in advance.
ModernElectric
Yes, this is what I have been searching for and couldn't find pieces of the puzzle to piece together. THANK YOU!!
I will use this as a building block and build from here.
Appreciate it.
abureaux
MVP Frequent Contributor
I believe this will work. Only did a couple of tests though.
abureaux
BTW, Looks like there is something wrong with your 6 and 7:
Should be this, I believe:
Not sure if you already noticed, but thought I'd mention.
ModernElectric
Appreciate it.
