Text box
985
02-20-2020 07:59 AM
DebraCrouse
Is there a way to make the text into a block so that the input can be seen in a block as opposed to just it keep going across the screen in one line? The "type" "text" doesn't seem to have that option.
Thanks.
BenTurrell
Hey Debra Crouse‌,
If you set the appearance field to multi line you will have that text block look.
Ben
If this answer has helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
