Survey123
1733
6
06-14-2024 10:21 AM
GISIntern21
I am trying to create how to have a line break in word templates for Survey123. I have tried \n and <br>. Any suggestions?
${comments}${field_83} ${field_85} ${field_87} ${field_90} ${field_92} ${field_94} ${field_96} ${field_98} ${field_100} ${field_102} ${field_104} ${field_106} ${field_108} ${field_110} ${field_112} ${field_114} ${field_116} ${field_118} ${field_120} ${field_122} ${field_124} ${field_126} ${field_128} ${field_130} ${comments_recommendations}
abureaux
MVP Frequent Contributor
Use IF. IF on its own acts like an "if not null, do the thing". In practice, there are two uses of IF in this context:
  1. On it's own, the field will only appear if it contains a value. E.g., ${if field_83}
  2. As a full logic statement. E.g., ${if field_83}${field_83}${/}
I much prefer option #2 as you can add conditional formatting. Try this. It will conditionally show each "field_xx" on a new line if it contains data.
${comments}${if field_83}
${field_83}${/}${if field_85}
${field_85}${/}${if field_87}
${field_87}${/}
DougBrowning
Did you try just enter in the word doc?  That worked for me I think.
abureaux
100% this. Feature Reports use normal MS Word formatting. HTML will not work.
E.g., If you want to color and bold your output, you'd just do that formatting to the tag itself: ${field_83} would result in My text output.
GISIntern21
Yes I tried that but some of the values are null and I don't want to have a blank space where there is a null value. Is there any idea to just showcase the values which don't have null values.
GISIntern21
My output look like this but I want it to be organized in different lines without the null values inbetween
abureaux
${field_87}${/}
GISIntern21
Thank you so much it worked 🙂
