Using Caplock with mask in Survey123 how can we have spaces between words?
5593
11
03-21-2018 07:52 AM
DiegoLlamas
I have been doing some test with caplock for my text fields in survey123. I was able to do it.
In Esri:inputMask y add this symbol > and xxxxxxxxxxx for the quantity of letters we think we will be using
We write with spaces in survey 123
But when we see the info on a map we can see the info but with no spaces between them
If we open the survey we send we see the same behavior. No space between words
I asume it is because in Mask we do not have any space between x but we do not have control what the user is going to write, so, my question is How can we have caplock for words and respect the space we put on them? is it possible?
>PLEASESAYYES
Thanks for your help!
Diego Llamas
BrandonArmstrong
Hi Diego,
One option might be to apply a regular expression in the Constraint column of your XLSForm
Something like the following...
regex(.,'^[A-Z ]*$')
Although this does not limit the total number of characters that can be submitted, it should limit valid submissions to all capital letters and allow for spaces in between
DiegoLlamas
Hello Brandon Armstrong,
I tried your suggestion adding regex to Constraint column.
But when I was doing some test my letters did capitalize and I got an invalid error
Now I know that Mask option will not help me to capitalize automatically the letters people writes in text fields.
Thanks for your help!,
Diego LLamas
BrandonArmstrong
Hi Diego,
The error you are getting is intended, as the regular expression is specifying that the letters must be all capital.
In your screenshot, it appears that the letters are lowercase, therefore warning the submitter that it is not a valid answer.  Adding a Constraint Message could give the submitter guidance, that the input must use capitals.
Please let me know if you have questions related to this information.
Best,
Brandon
DiegoLlamas
Hello Brandon Armstrong‌ maybe i didn't explain my self clearly. What I want to do is, even though my users use  lowercase to write in my text fields in my survey, I want that automatically the letters are capitalized. Using this symbol (>) with certain number of x (>xxxxxxxxxxxxxx) in esri:inputMask field I was able to do so. all my letters are capital letters but because in mask field I used >xxxxxxxxxxxxx.... with no space, all my word get together because in Mask there aren't any space.
what I want to know is, if it is possible to survey capitalize all my letters when I write something using lowercase and respect the spaces between words. As I said. I was able to capitalize letters using >xxxxx... but this does not respect spaces between words.
Diego
BrandonArmstrong
Hi Diego,
Unfortunately, Input Masks cannot be used to accomplish the honoring of dynamic spacing placed in the input.  You would need to explicitly define the placement of spaces within the Input Mask.
Best,
Brandon
DiegoLlamas
Hi Brandon,
And, is there any way i could capitalize my text fields automatically, I was trying using UPPER option y calculation field but didn't work.
BrandonArmstrong
Hi Diego,
The Input Mask can be used in order to force capitalization, but not to allow for the dynamic placement of spaces.  If the prevention of an input using a relevant expression does not work for you, maybe consider converting the input to uppercase post collection?
One option might be to use the field calculator in ArcGIS Online or ArcGIS Pro to convert the input of the field to all uppercase.
Best,
Brandon
LAG155
Hi Diego,
Hello I had the same problem!
To this day I solved it with JavaScript.
Generating a function to pass the receipt data to Uppercase
LMedeirosUI
Worked for me! ESRI really should have made this an option years ago, but at least other people figured out an elegant workaround. Thanks!
