Survey123 Webhook Question
800
05-19-2022 08:24 AM
JodiHeitkamp
I'm working with Survey123 and the Integromat (now Make) Webhook. I have the webhook in Make set up to populate a new row in Google sheets. Is there a way to go backwards? If I edit Google sheets, can I make the change automatically populate/edit a cell in the Survey123 database?
ZacharySutherby
Hello @JodiHeitkamp
You would likely need another Webhook that uses the Google Sheets connector as the trigger action that then uses the HTTP connector to send an applyEdits request to your ArcGIS feature service.
Thank you,
Zach
