Survey123 Webhook for Enterprise Portal?
2929
7
08-02-2021 12:59 PM
AlexP_
Hello,
I have survey123 connect and published it to web app. Do we have webhook for enterprise portal? I only found ArcGIS Online documentation. Please advise. Thank you.
Alex
Tags (3)
KrishV
Hi Alex,
See if below Technical article can help you..
https://support.esri.com/en/technical-article/000025025
Krish
Andrew-Bowne
You can use Integromat to publish webhooks connected to ArcGIS Enterprise.  At this point I do not believe Microsoft Power Automate works only with ArcGIS Online, not Enterprise.
AlexP_
@Andrew-Bowne
Thank you for the information. Is it free to use intergromat?  Do we have documentation for this?
Andrew-Bowne
Integromat has a free version that will work just fine if you are only trying to test. I think you can do 3 scenarios. After that you have to pay. You can find pricing here: https://www.integromat.com/en/pricing. It's really cheap and Integromat is a great product.
SebastienPetit
I am bumping up this post since the solution provided below seems out to date.
We have survey running in our ArcGIS Enterprise.
I would like to have my webhook on Microsoft power automate but it only connect to agol.
Did anybody managed to get it work with Enterprise?
Andrew-Bowne
DPU-SMAMUS
is there a solution for this? i have the same need here.
