Survey123 Report Photo not displaying
3912
11
02-02-2022 09:21 AM
ahagopian_coj
Hello!
I created a survey in Connect off an existing feature service that is hosted in AGOL.  I added an image question allowing the user to upload an image which works great.  However, I am unable to get the image to show in the report.  I can see it in the Data tab of the survey.  I can see it in a web map in AGOL.  But when I generate a report nothing is there.
Report attached.
Katie_Clark
MVP Alum
Unfortunately, it is definitely the fact that you have esriFieldTypeString in the bind::esri:fieldType column for the image question that is creating the issue. I tested with my own survey. You can see I submitted the same photo for both questions, and they both display in survey123.com
And here is the report template syntax:
And the final report:
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
DerrickWestoby
I'm about 12% sure that I've seen this mentioned before as a known issue when trying to create feature reports with images from a feature layer that wasn't created with Survey123 publishing (I'm fuzzy on this, so don't put too much weight on it).
If you submit a NEW record via Survey123, with a NEW image attachment, will the image show up in your feature report for that specific record?  If not, you can disregard my post.
