Survey123 Online Data tab not filtering date or datetime fields
413
02-23-2023 09:28 AM
CandaceHankins
We have seen this on multiple surveys in our organization and was not sure if it had something to do with the recent Survey123 update.
We are only able to filter date or datetime fields in the Data and Analyze tab of Survey123 by using "unique" instead of "value" with the calendar. The Apply button is disabled and there's a red warning on the filter, but no explanation as to why.
We cannot use the provided date range filter because this is the submitted date, which is not always the same as the date or datetime field we are trying to filter by.
I tested filtering in the Map Viewer of the layer and a "value" filter worked on these fields, so I am thinking this is just a Survey123 data page error?
Using "value"
Using "unique"
Richard_Purkis
Hi @CandaceHankins
Thank you for reporting this. This behaviour only started occurring since the latest update. It matches the behaviour in another thread. There is now a defect logged: BUG-000156082 : Unable to filter dates by value on the Survey123 website.
Richard_Purkis
Hi @CandaceHankins
Richard_Purkis
@CandaceHankins
The fix has now been released and dates are able to be filtered as expected.
Should you see any more issues feel free to get back in touch.
